Re: Off Topic...Starting diesel truck
Posted by Bob M on July 11, 2006 at 06:51:42 from (151.190.254.108):
In Reply to: Off Topic...Starting diesel truck posted by Tom Windsor on July 10, 2006 at 20:36:04:
I've had similar experiences several times on tractors and my old Kenworth flatbed. The cable conductor corrodes near where it's bonded to the battery terminal. Battery acid seeps under the cable insulation and slowly eats away at the copper underneath.
The cable will look fine on the outside. However when you pass cranking current through it, high resistance at the corroded area limits the current and causes slow cranking. AND it results in extreme heating of the cable at the point of corrosion. This heat in turn will cause the cable insulation to smoke, and can even burn thru the cable like you experienced.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
