Front Bolster Removal on M
Posted by turbos10 on July 23, 2006 at 11:50:25 from (76.0.74.207):
Hey all, I am planning to remove the front bolster and build a custom wide front on my M puller. I wanted to check with you guys and see if it is as easy as it looks. Best I can tell, with the front sheet metal, steering shaft, and radiator removed the assembly should slide out when the 4 bolts on each side are removed. What I am worried about is how tight of a fit it is and if I am going to have to loosen all the frame bolts to get it to some out. The reason I ask is because I was planning to tack weld my front weight bracket in place before removing the bolster because it will be the foundation for the new frame and front end. However, once welded, the frame rails will be one piece. If it will slide out when the bolts are removed, I will just block up the front of the tractor and use a cherry picker to pull it out. If that is not gong to work and I have to loosen everything, I need to change my plan a little. Lemme know what ya'll think. Chris
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
