Re: 706 specs transmission
Posted by K.B.-826 on July 24, 2006 at 16:36:53 from (68.115.105.176):
In Reply to: 706 specs transmission posted by dw64 on July 24, 2006 at 10:37:25:
Case-IH LOW ASH is the only engine oil that should be used. Anything else will lead to fouled plugs and burned valves. 30 weight during the summer and 10 weight during the winter. If you don't have a C-IH dealer nearby, go to your local CO-OP and have them match up a Low-Ash. Use a good quality name brand hydraulic fluid, just make sure to do a total drain and change so it's all the same brand, as additives in certain brands can react with the additives in other brands and cause problems. It's too difficult to describe the shift linkage adjustments, get yourself an I&T manual from your local farm store and follow the procedures for adjusting the clutch pedal, TA dump valve, transmission brake, TA linkage, shift linkage, and park lock linkage to the letter. Don't adjust one without adjusting the rest, they all affect eachother. The proper way to shift is- push the clutch pedal down 3/4 of the way and use the brakes to bring the tractor to a complete stop. Then push the clutch pedal all of the way down to engage the transmission brake. then shift. Never push the clutch pedal all of the way down while the tractor is in motion, as that will wear the transmission brake pad. The range transmission (Hi, Lo, R) should never be shifted while the tractor is in motion. The speed transmission (1,2,3,4) can be shifted while the tractor is rolling to get going in High 4 by pushing the clutch pedal 3/4 of the way down, but in most cases it's best to bring the tractor to a stop and engage the trans brake. Never engage the park lock while the tractor is rolling, as that is a sure way to bend the linkage or break a tooth off of the reverse driven gear.
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
