Re: Farmall 140 electrical ?
Posted by John T on July 27, 2006 at 05:42:55 from (66.244.90.5):
In Reply to: Farmall 140 electrical ? posted by Gary L. Lyons on July 26, 2006 at 18:35:19:
Gary, If its necessary to unhook the battery cuz OTHERWISE IT DISCHARGES WHEN SETTING, the problems (IF its still a generator) EITHER theres a short in the wiring or switch etc., OR ELSE the Cutout Relay (in a VR or a simple 2 wire CR) is bad n the points are sticking closed. If tapping on it makes the condition stop the cutout relay contacts are sticking. If the cutout relay points are sticking closed, when the tractors shut off an ammeter would swing over to heavy - discharge,,,,,,the genny would get warm,,,,,,and the battery run down very fast. Also, if the cutout relay points were sticking closed if you removed the belt the genny would spin like a motor. Unhooking the wire that runs down from the ammeter to the BAT terminal on the VR would prevent the battery from discharging and if its reconnected there would be a spark indicating a current draw. A new VR or cutout relay (maybe $50 or $60 or more) would cure the problem. Next, if its NOT a cutout relay problem and the battery slowlyyyyyyy runs down if its not disconnected, theres a short in the wiring or a switch etc. If you remove the hot ungrounded battery cable and attach the lead n alligator clamp end of a test lamp to the bare battery post and the other probe end to the unconnected battery cable, the light will glow if theres a short circuit path to frame ground. If so take the probe end and next search around at wiring and terminal locations n the BAT input side of switches etc cuz if you probe to where the short is the lamp will glow. Note, the lamp should glow if your on the switches output switched side to loads like lights etc cuz thats a normal path to frame ground and the batterys other grounded post. This all assumes the battery itself is not bad and discharges regardless if its disconnected or not. If its an alternator it may not be wired correct or bad itself or theres a short in the wiring or switches. Hope this helps, best wishes n God Bless John T
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
