Re: 12-volt or 6-volt
Posted by John T on August 01, 2006 at 12:22:15 from (66.244.90.5):
In Reply to: 12-volt or 6-volt posted by Derek Zwart on August 01, 2006 at 10:54:47:
Derek, is it reallyyyyyyyy an Alternator instead of a Generator??? Im like Old, there arent many 6 volt alternators used. If it has a Generator and a Voltage Regulator instead of an alternator, the VR may be labeled as 6 or 12 volt!!!!!!!!!!!!!!! Does it have a magneto or a battery powered coil ignition?? Cuz if its a coil ignition system and used a 6 volt coil WITHOUT any external series ballast resistor ahead of the coil, the coil would get so hot you could barely hold your hand on it plus it can go bad from overheating and the points will burn up prematurely. If it has an external ballast resistor after the ignition switch and ahead of the coil, then it may have been converted from 6 to 12 volts at one time. If it was a 6 volt and now a 12 and the starter wasnt changed, they spin like real fast but thats kinda hard to describe over the net As far as coil n points ignition (if thats what it has instead of a mag) it depends on if the batery is Positive or Negative grounded and it will still work regardless HOWEVER its more efficient if wired to match the ground. i.e. if Pos ground the coils + goes to the distributor while if Neg ground its - does. If its a magneto makes absolutely no diffeence as its not connected to the battery for power. The points n condensor woud be the same on a coil ignition regardless if 6 or 12 volts so they arent gonna provide any clues. If it were mine and if originality isnt a concern, since it already has a 12 volt battery and maybe?? a 12 volt alternator, I would rig her as 12 volts Negative ground n be done with it. If its a coil ignition it needs EITHER a full true 12 volt (internally ballasted) coil or else a 6 volt coil with an external series ballast resistor, but if a mag its no difference n youre good to go as is. If its a generator instead of an alternator it needs at least a 12 volt VR and preferably have the genny converted to 12 volts or get a rebuilt one or even try the present genny (6 or 12 volt) with a 12 volt VR n see how she charges and DONT FORGET TO POLARIZE the genny. If we had some pictures we could better help see what you have !!!!!!!!! You may wanna invest in a new wiring harness n check out Bob M's Wiring Diagrams. NOOOO the coil n alternator n genny n ignition and the points or ammeter etc or starter dont look much if any different to answer your question John T
Home
| Forums
Today's Featured Article -
A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
