Re: 200 not charging
Posted by John T on August 02, 2006 at 05:23:50 from (66.244.90.5):
In Reply to: 200 not charging posted by mattlobdell on August 01, 2006 at 19:49:18:
Matt, First of all its the Generator not the Voltage Regulator that needs polarized. To do that, first ground the gennys FLD terminal to the gennys case then momentarily flash jump a jumper wire from the VR's BAT terminal over to its ARM/GEN terminal and you should get a small spark. Same things accomplished if you ran any hot wire (like from BAT terminal on VR) and jumped it to the gennys ARM post. It passes current through the gennys Field windings in the correct electrical +/- polarity so as to impart residual magnetism in the gennys iron Field poles in the correct corresponding North/South magnetic polarity. In the event a genny were polarized opposite from how the battery is connected (+ or - ground) and wasnt correctly repolarized and a VR was connected, it could do harm to the VR. Thats why you should always polarize the genny as described above and thats also why a new VR has polarization warnings and instructions so the new VR dont get harmed. If the genny was polarized properly and the VR hasnt been harmed from connection to a reverse polarized genny and if she charges fine ONLY IF the gennys Field is dead grounded but NOT otherwise, the problem is either: 1) The VR is bad (field current control relay) 2) The VR isnt well grounded to the gennys case 3) The wires open from Fld on VR to gennys Fld I would polarize the genny,,,,,,insure the VR is well grounded to the gennys case,,,,,,,check the wire from the VR to gennys Field post,,,,,,,see if she charges OR if she never charges UNLESS you dead ground the gennys Field. Remember, if a battery is fully charged the VR is doing its job if it backs off the charge rate but usually right after a start up the battery is depleted sufficient that I would expect a good VR to call for high charge for a time at least. Best wishes n God Bless, post back your findings n any questions Check that VR to Genny case ground connection !! John T
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
