Re: 706 3 point hitch adjustment
Posted by the tractor vet on August 03, 2006 at 12:04:53 from (75.24.34.189):
In Reply to: Re: 706 3 point hitch adjustment posted by a4t1rat on August 03, 2006 at 10:12:36:
There are three hyd. pumps in that tractor one is for the steering, brakes, T/A , and lube of the transmissions and also running the hyd. oil thru the oil cooler in ft. of the rad . Then there is the hitch pump in the left rear of the tractor down in ft. of the left axel housing this is the pump that does the remotes and the hitch . And the other one is built into the PTO and that pressures the PTO . Now you may think that everything is ok on the remotes but even a 14 foot disk with a 3x8 cylinder on it can be lifted with and old H or Mwith the pressure set at 950 . Now if that tractor is bone stock then the system should pressure up to 1750 lbs with the stock releif if someone along the way needed more pressure then anything from the 1750 -2350 . But with what you say that it will lift when reved up no there could be a valve stuck and it is doing some bypassen or it could be like i said low pump volume . You can remove the top link plate and look inand see if there is a bunch of oil sprayen off the upper right hand side and if there is then you will have to remove the rocksaft housing to get to the unloader valve or if it is comming out of the hitch clinder same thing applys . The best way to figure this one out is take it in and have the system flowrated then you will know what the pump is putting out , Nah i ain't ah going to say it .
Home
| Forums
Today's Featured Article -
A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
