Re: coil replacement
Posted by John T on August 03, 2006 at 13:29:38 from (66.244.90.5):
In Reply to: coil replacement posted by '43 h on August 03, 2006 at 12:46:36:
43, I agree with Jim, a universal after market 6 volt coil ought to be close enough in its primary winding resistance to be suitable for most all old tractor points n coil type of ignitions including Farmalls, notwithstanding a few which still ran some external ballast even at 6 volts I believe. You should match the coil with whatever polarity the tractors battery is, i.e. if its a Positive ground tractor the coils + wires to the distributor while of its a Negative ground the coils - wires to the distributor. It would still produce a spark regardless but its most efficient if wired correct.
John T
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
