Re: 706 brake bolts
Posted by the tractor vet on August 07, 2006 at 07:32:58 from (75.24.15.235):
In Reply to: 706 brake bolts posted by jim mc dade on August 07, 2006 at 05:03:29:
Well there in there somewhere and it is wise to find them . Now as far as the bolts to put back in i use grade 8's , clean the holes out with either or acetone and clean the bolts as well then use loctite the blue stuff as ya may have to remove them someday and make sure that they are tight. Now for the pin they were a press fit to start with and the pin is harder then all get out so you may be able to drill it or put a couple of small tack welds on it 180 degrees apart about a half inch long with 7018 at about 120-130 amps on the back side of the pin to the bracket . Now when your going back together you have to BLOCK the park lock up 3/4 of and inch so that it will clear the gear , i use a 1/2 inch nut under the linkage on top of the range transmission cover . That spring is heavy and it WILL TAKE FINGERS OFF.
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
