Leaking Belt Pully Gearbox Gasket on H
Posted by awutay@worldnet.att.net on August 12, 2006 at 19:59:56 from (12.76.155.2):
I have the following problem on my ’41 H and its driving me crazy. When I bought my H it was missing the belt pulley gearbox and pulley. Covering the gearbox opening was a thin homemade flat metal plate and a gasket. There was some minor grime build up on the plate every once and a awhile, and I chalked it up to the non-factory standard part and the fact that the bolt holes were 2X the size they should have been (they were flame cut holes, not drilled) I finally got my hands on a belt pulley gearbox, cut a new gasket, and installed it using silicone gasket sealer as an added safety. Immediately I began to see leakage out of the back of the gearbox at the gasket (By leakage I mean about 2 tablespoons of tranny oil every time I shut down). I figured I had jarred the gasket out of position sliding it into place under the gas tank. After two more tries with new gaskets and silicone, oil was still leaking. So instead of trying to replace the belt pulley as I had, I did two things. 1) I checked the flatness of both the tranny case where the belt pulley gearbox sits, and also the belt pulley flange and 2) instead of trying to slide the gearbox into place under the gas tank, I removed everything in the area to allow me to install the gearbox unobstructed from above. The flange on the gearbox was flat. On the tranny cover, at the area it was leaking, it was dished inward .015 inches, certainly not enough to cause a problem, but…. When I reinstalled the gearbox a 4th time, I used a good bit of silicone on the back side and didn’t initially torque down the bolts (I let the weight of the gearbox form the gasket). The first time out – no problems. The second run a few days later and the gearbox is leaking again! As far as I can tell the gearbox is splash lubed, so there shouldn’t be any pressure that would force the oil out the back of the flange. So does anybody have an idea about what is going on? Art
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
