Re: International 584 advise needed
Posted by Fromjb2 on August 13, 2006 at 16:16:13 from (69.198.143.165):
In Reply to: International 584 advise needed posted by Rick Bright on August 13, 2006 at 12:49:22:
Hi Rick, the Lucas alternator will give out before long but can be easily replaced with AC Delco single wire alternator. Re lifting the front end of tractor off the ground, I believe it should but am not familar with Allied loader. My brother has IH 2250 loader on 495 which is same tractor but 3 cyl D179 engine, it will lift front end off ground no problem. Re parking brake, check adjustment as someone else has said but most likely has been driven with brake on and wrecked the band and probably the drum.
Costs many $$ to repair, have to lift top off range transmission, fenders, fuel tank and probably cab. If the crap from the parking brake band has settled to the bottom of the transmission then there is likely no problem but if it was done recently you may have to change hydraulic filter and Hytran fluid a couple times.
My brother fixed his 684 by a suggestion from old IH mechanic. Get a length of all thread bolt with an "eye" on the end, drill hole in right foot platform so "eye" of all thread bolt comes up between the brake pedals, put a nut on each side of the platform and adjusted length so when brake pedals are depressed a pin can be put thru the "eye" to hold the brakes locked on. Works great BUT must have good working hydraulic brakes.
Re PTO, that is normal you can turn it about 1/4 turn when engine if off, makes it easier to connect PTO shaft of equipment.
Re 3000+ hours, I would not worry about engine.
If oil has been change regularly and good quality Diesel fuel used these engines will run for many years. My brother has a 454 (3 cyl D179) from 1972 with over 15,000 hrs and still running great. Another hint if it has the Bosch injection pump add some Diesel fuel conditioner or a tablespoon of engine oil every time you refuel. The Bosch injection pump has a lip seal on the drive shaft from the timing gear and its only lubrication is from the Diesel fuel. 30 years ago that was not a problem but with the low sulphur Diesel fuel today the lubrication is decreased.
My 2 cents
JB2
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
