Re: Farmall F20 Over Heating Issue
Posted by Leroy on August 20, 2006 at 05:34:27 from (216.201.38.43):
In Reply to: Farmall F20 Over Heating Issue posted by WI Farmer on August 19, 2006 at 18:07:08:
Other replies are all good but not mentioned, might be an air lock in not letting the water circulate, did you have block drain open and refill till water was comming out and then close block drain as the water was flowing then finnish filling the radiator. That should make it so there is no pocket of air left in engine to keep the water from circulating (This is with every type of cooling system, thermosyphen or water pump. some systems even have a seperate bleed screw because of that problem), that pocket of air will cause the steam like that and there should be no steam at any time in running. Also a anti freeze mix will not circulate as easy as water and will cause steem when water will not even tho the antifreeze mix has a higher boiling point than water. Found out about the antifreeze on my JD with thermosyphen system when we put a mounted picker on, never boild before with anti freeze till picker then you couldnot seepicker for steam, took out antifreeze and refilled with water and no more steam. Used picker only part of season as picker went bad, in all years since no more boiling with antifreeze. Also on a different JD, same system when 4 tube radiator whent bad was replaced with a 3 tube (same gallons) and overheated, then had to ad the water pump, the bigger tubes would not release the heat fast enough without positive circulation. Check for that air pocket.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
