Re: 1206 injection pump
Posted by the tractor vet on August 21, 2006 at 13:25:23 from (75.24.29.127):
In Reply to: 1206 injection pump posted by 515ryanh on August 21, 2006 at 08:06:08:
On the right hand side of the bell housing there is a plate with two 1/4 inch bolts (7/16th) wrench size and under that plate is a timming pointer and on the flywheel it is marked off in degrees . Remove the two littel screws on the timing window and remove the plate make sure that you shut off the fuel at the tank first before doing this , Line up the two lines in the pump timing window and look at the flywheel it should be set at 8 degrees . Now on most 806-1206 with the D361 or DT 361 the things that make them hard starters are (1) slow cranking speed because of low cranking voltage or amp , Slowcranking speed because of a starter that is just about plum wore out. (2) low cranking pressure in the injection pump , (3) low cracking or breaking pressure in the injectors , (4) Low compression due to a wore out engine or valves wareing into the head thus lowering the compression of the engine . Also valves being to loose or to tight .
Home
| Forums
Today's Featured Article -
Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
