Follow up Question to John T. Nordhoff in Indiana
Posted by Grantique on August 28, 2006 at 04:45:15 from (66.194.132.200):
Good Morning John T.
This a follow up question to you on your excellant test procedure for tractor generators with cutouts and VR. I have a Farmall Super A with a rebuilt Generator, new Voltage Regulator, and new meter. I have a Farmall H with a cutout. I am focusing on the H first. From my previous post I am having problems seeing and charging on my ammeter for my Farmall H. The generator is rebuilt. The ammeter is new. The tractor has a cutout that is a few years old. Here are my findings from the good instructions you gave me. I have 6.05 Volts on each side of the ammeter. I have 6.05 Volts at the BAT terminal on the cutout. When I start the tractor I have 5.85 Volts on the ammeter and am showing a slight negative discharge. I have 5.85 Volts on the BAT terminal on the cutout. If I touch the Generator ARM post I read 7.5 to 8.0 Volts with the tractor running. When I jumper the BAT and GEN terminals on the cutout together my BAT terminal on the cutout reads 5.85 again. I am particularly interested in you reference to the Field wire going to the light switch. I have added ground wires to the generator housing and the light switch. I don't understand what is going on at/in the light switch. Can you give me some advise on what is going on. Also, the tractor lights do not change intensity when I rev up the engine but the ammeter goes negative by several amps. Thanks for your help. Repectfully - Larry
(Grantique)
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
