Re: White and Blue smoke
Posted by Fromjb2 on September 19, 2006 at 14:29:21 from (69.198.143.165):
In Reply to: Re: White and Blue smoke posted by Don Brien on September 19, 2006 at 10:16:36:
Hi Don, 784 should have German 4 cyl D246 engine.
D239 was used in 574,674,684,695. Same engine just slightly larger bore. They do like to blow white/blue smoke until they are warmed up or idling around doing nothing. You can reduce the smoking when idling by not pulling the STOP/START/RUN lever all the way to the top of the RUN position. Leave it down 1/4 to 1/2 inch and this will reduce the fuel going into the injectors and cause less smoking.
Have you owned this tractor all its life? Maybe someone cranked up the HP by adjusting the injection pump and it is being over fuelled.
JB2
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
