Farmall Tractors Discussion Board |
Re: Re: Re: Re: Alternator Conversion Wiring Diagram
Posted by Bob M on January 27, 2000 at 11:55:12 from (192.232.120.194):
In Reply to: Re: Re: Re: Alternator Conversion Wiring Diagram posted by Dave on January 27, 2000 at 10:50:45:
Dave - You pretty much got it. If you can start with a hand crank, you must have magneto ignition. (A mag is designed to give firing voltage at hand crank speed, and it operates completely independent of the charging system). But with coil/distributor, there's no current available until the generator is spinning fast enough to generate enough volts to cause the cut-out relay to pull in. This generally occurs at RPM's a little faster than normal idle. Thus you CAN start a distributor equipped tractor without the battery, but you gotta pull the tractor and get the motor spinning at fast idle RPM's before it'll start. (Been there, done that...) BTW tractor generators are not permanent magnet devices - they have wound field poles. Residual magnetism in the poles will generate a small voltage in the armature when it starts to spin. This in turn strengthens the field poles causing armature voltage to quickly build up to rated value as the rpms increase.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
