Re: No fuel pressure on 450D
Posted by Ron in Nebr on October 09, 2006 at 11:32:24 from (66.252.113.248):
In Reply to: No fuel pressure on 450D posted by farmhand on October 08, 2006 at 15:02:09:
Like the one post mentioned, and I mentioned last week, check the screen at the inlet to the scavenger pump. If that's ok, it's not too hard to pull the scavenger pump off the main pump housing. Two of the bolts on the back cover are larger than the rest, and these two hold it to the main pump. Once it's off, remove the rest of the smaller bolts and take the back cover off the scavenger pump. A few possibilities then to check for are: 1. The gears of the pump and the hex drive that drives them are held on the shafts by tiny rollpins. One of these may have sheared. 2. There's a small springloaded valve in the pump housing that may be stuck(Make sure you don't loose the spring when you pull the cover off the back of the scavenger pump). 3. This was the problem on my 650D- The pump is driven off of the end of the governor shaft inside the main pump. The end of the governor shaft is square, and there's a part that's rollpinned to the shaft of the scavenger pump that fits over the square end of the governor shaft. It looks about like a 1/4" drive socket and extension(sorry I'm not describing this real well but you'll be able to see what I mean once you have the scavenger pump off). Anyway, on mine, the square end of the governor shaft was rounded off. To fix it I took the whole main pump apart and welded up the rounded-off area then filed it until it was back to it's original square shape. I should note that I have a manual for the pump that helped me here. I was able to get a few seals from IH but had to make most all the paper gaskets myself. Hope this helps!
Home
| Forums
Today's Featured Article -
Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point
... [Read Article]
Latest Ad:
John Deere B 1943
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
