Re: road gear on H is shot
Posted by Josh in Pa on October 11, 2006 at 12:13:04 from (130.203.208.156):
In Reply to: Re: road gear on H is shot posted by Dakotaclassiccycle on October 11, 2006 at 11:57:31:
Its not hard, but its gonna take some time. You have to remove the cover over the transmission and final drive. (The big cast iron one that the steering column and seat attach to). You have to remove the hydraulic pump, and remove the coupling between the clutch and the input shaft of the transmission. The you can remove the transmission input shaft through the belly of the tractor. After this, the 4th/5th slider gear can be slid off the shaft. I also moved the detent in my shifting rail a little bit (1/16") so that it would really go into 5th gear. Its not hard, but your in for a bit of a job.
Josh
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
