Re: Man oh man.......engine block cracks........:-
Posted by Hugh MacKay on October 15, 2006 at 04:05:33 from (216.208.58.104):
In Reply to: Re: Man oh man.......engine block cracks........:- posted by Patrick Martin on October 15, 2006 at 02:49:14:
Patrick: Please, cann the Mr. MacKay, Hugh will do just fine, bear in mind I've been called a lot worse.
I've seen a lot of broken blocks in A, SA, 100 and 130. Folks used to claim you couldn't add antifreeze to the old thermosyphon A and SA without pre mixing. I guess likely they right if one only runs it 5 min, and probably not up to temp. I've added antifreeze to my SA many times, to bring it up to strength, but always when it was going to be worked for several hours. In my lifetime, I've had 3 - SA, 2 - 130 and a 140, and never had any problems. Now, I do live in a climate where your antifreeze has to test for -40F. Just maybe that keeps one a bit sharper than say for example folks that rarely see temps below 20F.
I've had folks say to me, long after the first damaging frost, "Do you suppose I should check the antifreeze in that little farmall I have?" Poor time to be asking in my opinion, but you know the problem, guy who services his car or pickup, checked that. I never would have believed so many folks could be so careless about the little tractor they bought for yard work.
I would almost bet money, that 95% of all C-113 and C-123 engines with cracked or repaired cracked blocks, happened as a result of freezing. They always break right behind the carburator. A few have happened as result of collision, but I'm betting the front axle will tell the tale on those, as it will be toast and block will be broken across the front.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
