Re: ignition system condenser
Posted by Janicholson on October 18, 2006 at 13:58:46 from (199.17.6.122):
In Reply to: ignition system condenser posted by SDE on October 18, 2006 at 13:23:02:
Condensers die several types of death. The worst is intermittant operation that disapears when looked at but dies in the field. Condensers are a solid state device that unless physically damaged, or leaking goo, should not be changed if the points are wearing evenly and light grey color. (I know the argument may start, but I have seen as many bad new condensers as bad old ones) When they die it is usually a temperature related compromize that begins to breakdown when hot. Other times, they just short out internally and it stops sparking. They are basically two layers of rolled up aluminum foil with waxed paper between them, and the case connected to one layer of foil, and the lead connected to the other. If the connections break internally, they quit working. If the waxpaper (called a dielectric) "punctures" they short out and quench the spark very early. Testing with an OHM meter set on R X 1 is as follows: short the condenser so it is discharged. closing the points will do that with the ing off. Then disconnect the coil from the dist. and put a piece of paper in the point gap. Touch the + ohm meter lead to ground, and the - lead to the terminal on the side of the dist. Watch the meter, it should show just a few ohms then steadily get more and more resistance over a few seconds. This is a modest test, and only uses a volt and a half or so from the ohm meter. (they normally see about 250 to 350 volts when in use in the circuit) Thus to really check it a capacitor condenser checker must be used, (or replace it) Good luck, JimN
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
