4farmallman said: (quoted from post at 13:06:00 04/11/09) I have a 1964 gas 706. How does oil get to the rocker assembly under the valve cover? A while back I took the head off my 706 and had it milled because it was leaking around the head gasket. Today i took the valve cover off to retorque the head bolts and there has been no oil at all getting to the rocker assembly or anything under the valve cover. Thanks
Oil is metered through one of the camshaft bearings and then routed to come up around a head bolt up to the rocker arm shaft. If the camshaft bearing in not installed so that both oil holes line up with the holes in the block there will be no oil available to go up into the head.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
