Re: GRRRRRRRRRRRRR!!!!!!!!!!!!!!!!!!!!!!!
Posted by SuperA-Tx on October 20, 2006 at 07:30:40 from (4.90.6.11):
In Reply to: Re: GRRRRRRRRRRRRR!!!!!!!!!!!!!!!!!!!!!!! posted by Patrick Martin on October 20, 2006 at 04:24:39:
OK what I have is for a Super A but when Case printed it out it looks like it is for a 140 instead. Anyway I'll post the names and parts numbers for you since I dont know what kind of tractor you have.
The long bar is called "link lift", part #520076R11. Theres a nut, jam nut, self opening cotter pin, and washer as well.
There is also a "collar" part #2638X, it has a set screw.
Then three is the "trunnion lift link" part #520066R1
Last part of that arm is "lift link cushion spring" part #520712R1.
On a 140 below that arm is another arm called the "lift helper arm". I dont think Super A's came with this but 140's did, least on the ones I have seen.
On the 140's theres what i call a "hook" at the front of the link lift arm. On my Super A it is just a straight bar with two bends.
I am looking for that conpression spring now, I have the rest of the parts. The Spring on a 140 is lots bigger than for the Super A. The link lift arm is lots thicker as well.
On the four 140's I have access too the rocker arms are all a little differant. Mainly on the bar that sticks up that you attach the link lift too on the top of that arm there is another kind of "rectangle plate" that sticks up that bolts to the rocker arm and then the lift link. All ours have fast hitches so this may have been something that came with that set up.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
