Re: Farmall 450 Diesel Valve Lash specs
Posted by wdrew24 on October 26, 2006 at 21:13:48 from (24.74.43.5):
In Reply to: Farmall 450 Diesel Valve Lash specs posted by Gregg K. in KY on October 26, 2006 at 14:54:27:
I like to do it one time only. So I use a 20 thousandths gauge with a stone cold motor. I turn motor by hand until #1 is top dead center with rotor button at #1 tower. (of course the mark will be aligned with the pointer) Set both intake and exhaust on #1 at this time. Before you turn the motor, take a ruler and chaulk a line across the front of the balancer. (this way you can turn motor 1/2 turn and then adjust #3 both valves) Turn motor another half turn and mark will line up with the pointer again. Now adjust #4 both valves. Turn motor another half turn and now you do #2 both valves. After you have done all this...Throw the lever to the gas start position and check your starting valve adjustment. The IT manual gives you the distance for this. This is how I do it. I throw the lever as previously stated. I then mount a dial indicater above one of the four starting valves and taking a brass drift, I push down on the little valve cap as far down as it will go and then set dial indicater to zero. When I release the down pressure I get a reading...this is the clearance factor that you need. This adjustment is made by either lengthening or shorting the rod that runs behind the carb. I have found that a dual fuel motor don't like to start if the starting valves ain't set right. Believe me...It is easier to check and adjust than the book I just wrote. If you need any more help on your dual fuel tractor...call me at 704-622-2134 DREW
Home
| Forums
Today's Featured Article -
Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
