Return of the H starting problem
Posted by Hbauer from Vt on November 11, 2006 at 19:25:24 from (12.76.194.240):
Okay guys ( any gals out there too?), try this one.
Farmall H. wont start. I took down carb and cleaned it out. No difference.
I previously replaced, points, condensor and coil.
No difference.
Friend and I took apart the distrib today. It appears the points do not always spark when open and when they do, it is yellow spark.
Thus I have intermittant firing of the points...this appears to be a short from points to the distrib body. Only thing I can figure is defective points grounding at pivot post. I checked condensor wire...it appears okay.
One thing I am correcting is a #4 cable on one of battery posts...I bought a #1 cable and will install tomorrow. Push start button switch gets hot easily..possibly caused by small cable...or maybe switch is bad, but this would not be related, unless it is sucking juice from the starting circuit.
If the battery is strong enough to spin the engine, it should not be the problem..right or wrong?
Any bright ideas for this dope??
H. Bauer
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
