Re: super m valves
Posted by ChadS on November 19, 2006 at 11:55:52 from (66.228.96.130):
In Reply to: super m valves posted by makinhay on November 19, 2006 at 09:54:33:
Governor, or carb, or the gaskets leaking. Take the carb bowl off,,, set the throttle to the lowest postion, reach up inside the carb, and try to move the butterfly,, if it moves without resistance, you dont have the tang lined up on the throttle shaft, or the tang itself is worn and the slack will cause it to do that. The butterfly, at idle postion should be held shut by the governor, (when the engine is off) any free movement, check the linkage,,,, make sure the vertical linkage inside the governor is in adjustment, if its out, it will idle when you first start it, but as soon as the governor activates, it wont go all the way back to idle, so, you make the adjustment, with the throttle in idle, and you adjust the rod until the butterfly is held shut tightly. Other possibles, can be a vacuum leak, but it would be more erratic running than idleing high,,,,, Hope this helps a little. ChadS
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
