Re: 656 missing
Posted by Janicholson on November 27, 2006 at 07:06:15 from (199.17.6.122):
In Reply to: 656 missing posted by Jay (ND) on November 26, 2006 at 12:00:15:
A worn intake valve guide, rings not seated/worn/lost their temper/cylinder scored, will all cause the problem if it is not the ignition issues noted below. a cylinder compression chack, leak down test, or checking stem clearance with the spring removed on the intake (put the piston at or near TDC and stuff a 1/4" rope in the sparkplug hole to prevent dropping the intake valve down the cylinder). JimN
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
