Farmall Tractors Discussion Board
Re: I need more help with 656D
Posted by Joe Acker on February 02, 2000 at 13:58:15 from (138.26.110.197):
In Reply to: I need more help with 656D posted by matt on February 02, 2000 at 12:47:21:
Their are two types of 656 made IH and Farmall also could be gas or diesel. Woulsassume the one of which you ask is a Farmall. Some of these tractors had one set of hyd. at rear and one under fuel tank ( mid tractor )- many tractors used for bean , corn or loader tractors . PTO should be 540 only unless someone has changed out the chunk - check PTO under load to determine slippage as this is hyd. setup - look at front end to determine stability including tie rods and center mount, engine should operate with some blow-by- very cold natured and must use glow plugs even on summer day and shut down ten min. -- now for the good-- excellent tractor , just the right size, although rated at 67 hp. will outperform the newer tractors, 6 cyl eng when it hits the govenors with load is sweet music , currently have both the IH (utility ) and Farmall versions - price is about right for our market here-- noise and jump in trans could be substantial problem would suggest taking front panel below steering wheel , look at linkage make sure it is tight and is pushing gear linkage all of way in , you might even readjust, also check TA to be sure it is releasing properly and letting gear fully engage , if this does not work tractor most likely would need to be split, would suggest that you also drop hyd filter and check for metal in filter or housing
Post A Followup
: Re: Re: I need more help with 656D
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
