Re: Stuck Farmall M
Posted by No tools on December 13, 2006 at 18:28:24 from (71.79.44.154):
In Reply to: Stuck Farmall M posted by linemanfarmer on December 13, 2006 at 15:13:13:
Linemanfarmer
If that cylinder has not been full of water for a long period of time this may work for you.Remove valve cover back the valve adjuster off so that the valve are closed.
Take a old spark plug break the porcelain out of it. braze a fitting on it for air.put a 50/50 mix of anti freeze in cylinder put air on it leave it for ever amount of time you wish.Anti freeze well pentrate the corrosion the air will push it down through.water makes rust.(corrosion) water will dissolve it.If real bad it well not work.
Bill
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
