Re: CONFUSED!?!?!?!?!
Posted by Janicholson on December 17, 2006 at 07:46:02 from (66.173.50.42):
In Reply to: CONFUSED!?!?!?!?! posted by H fanatic on December 16, 2006 at 22:49:23:
Unanswered first: A groove cut in the outside edge of a piston that is not a ring groove is a heat dam. These are used to prevent combustion heat from traveling down the metal of the piston directly. Their use is quite common. cleaning them is a good idea if one is careful not to remove much metal. A ring groove cleaner with a cutter ground down to fit works well. Ring gap provides a space for the ring to expand Circumferentially and still not touch end to end (which would sieze the engine). Ring gap should be measured in an unworn location in the bore. If looked at in a location that is worn, it is not accurate. Unworn locations can be found at the bottom of the cyl. Usually 1/2" up from the very bottom. Another location is above the top ring/ridge. (if and only if this area has never been ridgereamed or honed in some abnormal way). In all cases the tightest gap measured on a ring in various locations in a bore, can be assumed to be the tightest spot in the bore) One way to approximate bore taper/wear is to measure ring gap in the most worn spots (just below the top (1/16") of the ring wear area), and at the bottom as noted above. The change in Circumference converted into diameter will indicate taper in the bore (not as accurately as a set of cylinder micrometers used correctly, but good enough to determine if a cylinder is worn drastically. All single piece oil control rings are old technology and should (in almost all cases be replaced with three piece rings with (effectively) no gap. Cleaning the ring groove is drastically important, as is doing it without removing metal. The groove clearance (side of ring to ring groove) is important because if too large it causes a pumping effect of oil around the back side of the ring. RIng groove taper (wallowing out of the squareness of the groove) is also a reason to junk the piston. Or if it is irreplacable, the groove can be cut wider and a steel repair ring can be inserted (they look like a scraper rail from a three piece oil ring) to take the piston back to usable. I hope this helps, good luck, JimN
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
