Re: Farmall 340 hydraulics adjustments
Posted by Hugh MacKay on December 24, 2006 at 04:02:23 from (216.208.58.162):
In Reply to: Farmall 340 hydraulics adjustments posted by Joe Werner on December 23, 2006 at 12:45:57:
Joe: It could be the linkage from the hitch control valve to the hitch lift cylinder. I'd check that one first. If you find the linkage intact, the problem has to be inside the control valve itself. There are a set of spider gears in there, much like a differential, they tie control lever side to the other side with lever the linkage from cylinder hooks to. It those spider gears break up it gives same effect as linkage being unhooked. I have no idea if those gears are still available. They were in the 1970s when I broke my first set. They were expensive back then, thus I just replaced the entire control valve with one from a 300 parts tractor I had. I lost draft control, in the change over. I was not using my hitch for in ground tillage thus draft control was not important to me. If you want the draft control working those spider gears have to work. Any hitch valve from a 230, 330, 350, 450, 240, 340, 460 or 560 will work and have draft control. If draft control is not important you can add 300 and 400 to the list and any control valve from all of these tractors will work. I give you this as should you decide to go that route. Personally if I were repairing this and draft control mattered, I'd buy new gears, your chance of getting a valve with gears that have long life left in them are slim.
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
