Re: polarity on coil
Posted by JayWalt on December 29, 2006 at 19:23:16 from (24.223.138.48):
In Reply to: polarity on coil posted by deene on December 29, 2006 at 19:12:06:
Generally speaking, whatever terminal on the battery that does NOT go to ground, is what the hot wire goes to on the coil. Most older tractors are positive ground, so the hot wire goes to the neg of the coil. Hope this helps. In addition, the wire coming from the distributor gets grounded by the points, so that needs to go to the side of the coil which the tractor's battery terminal is grounded to.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
