Re: Need in Depth Technical Help for my charging s
Posted by Bob M on December 31, 2006 at 11:20:36 from (69.205.124.61):
In Reply to: Need in Depth Technical Help for my charging syste posted by JayWalt on December 31, 2006 at 10:16:50:
JayWalt – From your description your charging system is working fine EXCEPT the voltage regulator is set too high. (You should see 7.0 – 7.5 volts across the battery posts and an ammeter reading of 5 amps or so with a fully charged battery). My recommendation is to replace the voltage regulator with a new one. Properly adjusting a VR requires specialized equipment and is kinda fussy to get right. However if you wish to attempt to reset your existing one here’s how: 1 – Remove the regulator cover and identify the voltage regulator relay (it’s the one with the coil wound with many turns of fine wire and with it’s contacts held CLOSED by spring pressure.) 2 – With the battery fully charged, start the engine and let it run at governed RPM for 5 – 10 minutes to stabilize the battery and get the generator to operating temperature. 3 – Connect a voltmeter across the battery posts. Now gently bend the regulator relay spring hanger (or adjust the adjusting screw if provided…) to slightly REDUCE the spring pressure then check your voltage reading. Shoot for a reading of about 7.2 or 7.3 volts. TIP! Make adjustments in small increments! It takes only slight change in spring pressure will make a dramatic change in voltage. 4 – When you a finished the voltmeter should show 7.0 to 7.5 volts and the ammeter should indicate around 5 amps at full RPM. Good luck and hope this helps!
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
