Re: M backfires won't start! HELP!
Posted by Janicholson on January 07, 2007 at 18:50:50 from (66.173.50.22):
In Reply to: Re: M backfires won't start! HELP! posted by granger on January 07, 2007 at 14:16:49:
If gears messed up in the fromt engine cover, they can affect operation (usually do). I would put the engine at TDC on Number one cyl (front). Do this by pulling the sparkplugs from that cyl and while it is cranked (by hand preferably) place your thumb, or a cork in the cylinder when it is on compression, it will blow your thumb out. Then watch the timing marks as stated below, to get it at TDC. Then pull the cap and look at the rotor. It should point to the #1 plug terminal inside the cap. If it does not, or if it is way hard to get it to TDC by the compression with thumb idea above, I would suggest it has broken parts in the timing gears. Do not try to start it or run it or pull it to get it going until these things are checked for sure. (sevier dammage can be created where minor damage is located now. As stated below, it is mandatory to have a working relief valve on the system. Hoses will split, castings will break, and danger is likely. If your M is factory Hydraulic, it is equipped (may not be working) if it is put together by others it may be missing the bypass pressure relief. Good luck, JimN
Home
| Forums
Today's Featured Article -
Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
