Re: 6Volt Starter
Posted by John T on January 08, 2007 at 19:53:43 from (66.244.90.5):
In Reply to: 6Volt Starter posted by Mike Broome on January 08, 2007 at 13:49:45:
Mike, My general rule of thumb beginning point is if when you depress the starter switch the lights dim way down badly and/or the battery voltage drops down drastically, the switch is okay but the starter is the problem (BUTTTTT it may JUST be mechanicaaly stuck/jammed, check that first by loosening thE startEr and/or rocking the engine over). Next anytine the starter fails to crank I always advise you to remove, clean n wire brush, n reattach each n every battery n starter n switch n ground cable connection FIRST. It may just be a bad cable or connection problem!!!!!!! Next, insure the batery is good and have it load checked, even if the starter n switch n cables are alllllll perfect, if thE batetry is weak or bad NO CRANKING...... Next if the battery n cables are all good n the starters not mechanically stuck/jammed but if you depress the switch the lights dont dim and the battery voltage dont drop, then I suspect possibly its ONLY a bad starter switch ALTHOUGH the starter could be bad like the brushes !!!!!!!!!!!! If the switch is a stand alone 2 terminal (like the pedestal mount instead of the saddle type right on the starter) its very easy to use jumper cables to by pass jump around the switch to see if its just a switch problem. You simply jump hot battery voltage direct to the starter post n see if she cranks then to figure if the switch is bad. If the switch is a saddle type direct on the starter, remove it n see if its all burned up n carboned) new swich may fix the problem) and/or the copper starter post is all burned up n pitted (needs new post) Finallyyyyyyyy if its the starter typical causes may be the brushes are worn too low or the bushings are bad and the armature is dragging or the arnmatue is bad or shorted. let us know what you find John T
Home
| Forums
Today's Featured Article -
An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
