Re: F-14 Starting
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by F14 on February 05, 2000 at 11:26:06 from (204.176.212.3):
In Reply to: F-14 Starting posted by RED Blooded on February 05, 2000 at 11:10:04:
Yes, that lever is the spark advance. Fully clockwise is fully advanced. Probably as good a place as any for it if you're pull starting it. The part that the advance lever hooks to on the mag is also the cover for the points. Pop it off, clean the points and gap 'em to .013. Pull the distributor cover off the mag and wipe down the rotor and the distributor buttons with some carb or brake cleaner. While you tow it slowly listen to see if you hear the mag impulse coupling snapping. If you don't, squirt a little WD40 in the oil cups and try again. The impulse "snaps" the mag past the coil so you can get a good hot spark at hand-cranking speeds. If it isn't working, you'll have a heck of a time starting her. Check the plug wires. They go through a tube around the back of the engine, and it's a pretty tight fit. If there's bad insulation, it'll ground out the spark. Pull the plugs, clean 'em off, gap 'em to .025 or so. Pull the valve cover off and make sure the valves are free. If it has a small tank on the hood for gas, flush it out and fill it so the tank gravity feeds the carb. That way you don't have to fuss with the fuel pump right now. Unless the mud daubers have built a condo in your carb, that ought to at least get her to fire.
Home
| Forums
Today's Featured Article -
Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
