Re: 48 Farmall M starter problems
Posted by Roger Mills on January 20, 2007 at 08:33:42 from (71.213.68.25):
In Reply to: 48 Farmall M starter problems posted by cheinzle on January 19, 2007 at 21:27:43:
Had the same problem on a Minnie Mo Z. Four cylinder gas engines come to rest in two places so the starter drive gear engages the flywheel in those same places most of the time. It wears the teeth and eventually the bevel on the teeth gets worn flat-then the starter drive gear will hit the flat end of the ring gear tooth and jam. Turn the engine backwards and it will release the bengix tension. Pull the starter and use a dremel with a carbide (or better) bit and grind new bevels on the bad teeth. Look at nearby teeth for a pattern and make sure to grind down the worn area of the teeth to be flush with the valley between them. Put a new drive pinion gear on the bendix and it should last quite a while. The 6 volt starter jumps very fast with 12 volts on it and this accellerates the wear.
Home
| Forums
Today's Featured Article -
A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
