Re: Farmall C overhaul
Posted by Janicholson on January 23, 2007 at 18:32:12 from (66.173.50.65):
In Reply to: Farmall C overhaul posted by thumbanger on January 23, 2007 at 15:00:50:
Here is my take on it. There are few parts available (one can find some gears, but no housings. Disassemble and clean with carb cleaner to bare metal (include the strainer in that) the cap (covering the gears) is usually worn some where the gears press against it, laeving a mark. This needs to be flat sanded out with 240 silicon carbide paper on a piece of glass (flat). move the cover in random directions and press down evenly while sanding. change to 400 grit to finish it nicely. Use a feeler gauge set to assess the clearance between the gears and the side of the housing. if it is more than .0015" between them, I would try to get a better housing. The cover to gear distance should be set with very thin gaskets (some are available) these should allow only .001 to .0008" clearance between gear and cover. Can be checked with plastigauge. When finished, put liberal amounts of engine assembly grease/lube in the gears and housing (including the shaft/housing area. This assists in the priming of the pump on first startup. I hope this helps, JimN
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
