Re: Need Farmall 100 stuff!!!!!!!!! :)
Posted by Hugh MacKay on January 28, 2007 at 02:48:23 from (216.208.58.157):
In Reply to: Re: Need Farmall 100 stuff!!!!!!!!! :) posted by Patrick Martin on January 28, 2007 at 01:55:32:
Patrick: There are a couple of routes you can go, first would be find a 1 point fast hitch, then go fast hitch plow and disk. Then the problem comes with your mower, belly mowers don't work well without removing part of the hitch. Belly mowers also don't fit in well if your using the tractor for jobs like front blade, plowing, disking or cultivators. Problem is you have to remove the mower every time you do those other functions, and that will be a 3-4 hour change over every time.
You could go 3 point hitch for all of plow, disk and mower, even the cultivator. The change over would be quick and you wouldn't need to remove the front blade or at least the push frame for any of the rear hitch mounted implements.
I've been experminting with 3 point hitch to work in conjunction with my 1 point. There are photos of this in the YT gallery implement section. I have been using two 2x12 plows, one is 1 point fast hitch and the other 3 point hitch. I decided if my 3 point hitch would do quality plowing, that would be the true test. To date the 3 point plow will not match my 1 point plow for quality. It's close but not close enough for my liking. The bigger problem is I can't pull the 3 point plow as easily as the 1 point. That alone affects the quality of plowing. In the spring I intend to find a single bottom 3 point plow, and try to get more of the kinks out of my hitch. However I will not be satisfied until the 3 point plow works as well as the 1 point. Bear in mind I am damn fussy, maybe too fussy.
I noticed your e mail and will respond later today.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
