1982 Model 784 Diff. lock Issue
Posted by Mich John on February 01, 2007 at 12:26:17 from (71.227.27.80):
I managed to free up a stuck diff. lock system by spraying penetrating oil between the lever and the diff case and tapping the pedal. Now I have the reverse issue - it will not dis-engage. I took the rod loose from the pedal and tapped on the lever but it would NOT release the diff lock. I don"t have a good schematic showing what the diff. lock fork engages to lock the diff. How much force (torque) could I apply to the lever without causing an issue. I will try to apply a vibratory load to the lever next to see if it breaks anything loose. Anyone else faced with the same concern and fixed or have any suggestions?
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
