Re: 544 - Good or Bad
Posted by chadd on February 12, 2007 at 09:24:57 from (155.92.31.97):
In Reply to: 544 - Good or Bad posted by RSCO on February 11, 2007 at 18:22:22:
The 544 is a good tractor overall with some exceptions. The rear end and assorted components are designed to handle more power than the engine has, so you shouldn't need to worry about an overstressed tractor. It is nimble, and great for tasks like raking, fluffing, loader work, cutting hay, light baling, etc. However, if you plan on doing any pulling, I would probably go to a different model. The C-200 (which is in this tractor and our 2500A) is rated at 55 horsepower, but it doesn't feel like the same 50 horsepower that a 400 would have. The engine in it is essentially a tightly wound small displacement motor(it only has 35 more cubes than a 350). It has the horsepower at high end, but doesn't have the low end torque of the older M's, 400's etc. It is however, very smooth running and well balanced. If you are doing any pulling or heavy field work, hold out for a 656. They have the pulling power, but are still small enough for light duty.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
