Re: Diode Warning Light
Posted by Owen Aaland on February 16, 2007 at 19:48:07 from (65.165.246.115):
In Reply to: Re: Diode Warning Light posted by SuperA-Tx on February 16, 2007 at 13:16:36:
The circuit for the light for the alternator works by being grounded by the regulator. The circuit starts at the ignition switch, goes through the lamp and enters the excitation circuit of the regulator (I terminal). The base must NOT be grounded. The light works by battery voltage coming from the ignition switch, passing through the lamp, and entering the voltage regulator where it is grounded by the excitation circuitry. Since the excitation circuitry in the regulator has some resistance the lamp will not be as bright as one that has a grounded base. When the alternator starts to charge voltage is applied internally to the excitation terminal. This voltage will be the same as the other small terminal, the control circuit (A terminal). Charging voltage from the output (B post) goes to the ammeter and down to the ignition switch. Now there is charging voltage on both sides of the lamp. With both sides of the lamp at the same voltage the lamp goes out. An alternator failure would cause the voltage to drop at the I terminal and the light would again come on. This is not entirely failsafe because a failure internal to the regulator creating an open circuit will cause voltage to drop at the I terminal and not be grounded. In this case the alternator will not work and the light will not come on. This is one reason to make sure the light is on before the tractor is started. When the switch is turned off, the resistance of the lamp is enough to keep the back feed amperage below the level needed to run the ignition system. In this set up the lamp must be good to provide the necessary voltage to the I terminal to excite the alternator. If the bulb fails, the alternator will not start charging. Usually there is a small resister across the lamp terminals to allow the alternator to begin charging even if the bulb fails. This resister also causes the lamp to glow less brightly than it would if it were directly grounded. Ideally the control circuit (terminal A) should be connected as close to the battery as possible, normally at the battery cable on the solenoid or starter switch. That allows the alternator output voltage to be higher than the voltage that actually reached the battery to compensate for voltage losses between the alternator and the battery. The electrical load on these old conversions is so low that the control circuit can be connected to the alternator output terminal with no ill effect.
Home
| Forums
Today's Featured Article -
Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
