Re: F-4 Magneto Question
Posted by Roger Mills on February 18, 2007 at 07:18:30 from (71.213.68.215):
In Reply to: F-4 Magneto Question posted by Tom43 on February 18, 2007 at 06:13:18:
While Magman rebuilds mags and is lurking about the forum, and knows all. Some info that may clear up things in general: some mags do not have an impulse coupler but MOST do. It retards or delays the spark and the snap increases the output so it will fire when you crank it or spin it with the starter. General rule is that the impulse should snap at or just after TDC so the engine will not kick back and break your arm or the starter. When the impulse is spinning fast enough it 'kicks out' and the timing reverts to normal. Normal can be a manual advance/retard lever or fly weights that move outward and advance the spark with rotation speed/RPM, OR rarely, both BUT sometimes neither. Different engines have different timing requirements and these are part of the design of the ignition system for that engine. The initial timing of any engine is part of that design--if they use the impulse snap as the criteria then it assumes that the points are set to proper gap AND the correct mag is installed and working correctly. If they use the points, usually a distributor ignition, then it is when they just open and you use a meter or something like it to see when they "just barely" open. If they have a manual advance lever it should be in the full retard or specific 'start' position and is specified in the tune up specs from the manual. If no specs exist for a given engine then this info can get you close without breaking something when you try to start it.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
