Re: oil galley plugs in 123 engine?
Posted by El Toro on July 05, 2007 at 16:38:15 from (205.188.116.73):
In Reply to: Re: oil galley plugs in 123 engine? posted by BIG RED 1 on July 05, 2007 at 11:22:11:
third party image
I would drain the oil and remove the oil pan and pull the pump. Then I would use an air hose and blow out all those oil passages with air pressure.
If the shop removed the plugs I would ask the shop
if they reinstalled the plugs after cleaning the block. I wouldn't run the engine until you find the problem as you can damage the new bearings and crankshaft without any oil. Hal
PS: Make sure that pickup tube on the oil pump
is submerged in oil.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
