Either...or.
Posted by A. Bohemian on July 05, 2007 at 19:14:39 from (207.170.88.192):
In Reply to: Re: Super A troubles posted by glennster on July 05, 2007 at 14:45:21:
From your description, it could be either bad spark caused by an ignition component overheating (likely the coil or condensor), or crud in the fuel system (likely the tank). Statistically, rust in the fuel tank is MUCH more common than a bad coil, especially if the tractor is kept outside. So, start by physically examining the inside of the tank for rust. A flashlight and a dentist's mirror help. You can also check the sediment bowl; if there are fine particles of rust in the bowl, the odds are good there are larger ones in the tank. If the fuel system checks out ok, try the following. Get a plug and gap it all the way out to 3/16". Pull a spark line and pop it on the plug. Clamp the plug to a good grounding surface and crank away. You should see a nice, fat blue spark. I'd probably take the time to check all four, but only remove ONE line at a time, so you don't mess up the firing order. Keep the plug with you. The next time the tractor stalls, hop off and IMMEDIATELY and check the spark with the 3/16" plug. If it is yellowish and weak after stalling, but returns to normal after your self-described 15-20 seconds, it is at least possibly an electrical problem; the coil and the condensor are the most likely suspects, but it could be points, rotor, a loose connection... Please let us know what you find. This is an interesting one.
Home
| Forums
Today's Featured Article -
Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
