Re: A couple more thoughts
Posted by ScottyHOMEy on July 05, 2007 at 21:16:10 from (71.241.200.22):
In Reply to: Re: A couple more thoughts posted by chadd on July 05, 2007 at 19:58:37:
If you've got your clutch freeplay in the 1-1/8" range that George set you up on, and things are working right, you've got her licked. Loaded tires and the like will make your tractor feel heavier on the clutch but, in the end, she'll be right. You mention a grinding, which could be matter of rivets in the clutch facing grinding against the flywheel or the pressure plate, but I think that's a remote possibility. (If it is the case, yes, you need a new clutch disc, and as long as you've got the tractor split, you might just as well adjust or replace the cover and pressure plate. More likely it's the gears in the tranny running up against themselves. A Farmall thing, not to worry. Please do remember that theese trannies are not synchromeshed. The only way to put the old darlings into ANY gear is to stop, clutch, and let the driveshaft come to a rest before going into gear. Except that that last little crunch before going into any gear is a given on these tractors if you haven't held the clutch pedal down long enough. Pick any gear you want, but don't harbor any notions of shifting up through the gears. At least quietly. Bottom line . . . If your freeplay is alright at the pedal and she goes ahead under a load okay, you're fine. If, in getting the freeplay right, you found yourself running out of thread, then replacing at least the disc and, as long as it's split and you're in there, the pressure plate/cover is the route to take. If she's holding fine where you are with some room for further wear, I'd say don't touch a thing after you've got the freeplay where you're happy with it. I hope I've helped.
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
