Re: Inconvenient Truths
Posted by mark on July 06, 2007 at 09:03:26 from (172.145.113.104):
In Reply to: Inconvenient Truths posted by A. Bohemain on July 06, 2007 at 08:15:01:
Well, let me toss a morsel in the pot and give you my 2 cents worth.
I'm not the sharpest knife in the drawer, but over the past 50 years of life, I've managed to pick up on a few things:)!
I rebuilt the hyd. reservoir on my SA and I think the SC has the same unit....or very, very similar.
It does not require a brain surgeon or an extensive shop. In fact, I found it to be dirt simple and a straight forward repair. Yes, be clean...and then use a dose of horse sense (follow instructions).
I took my unit off the tractor, lugged it over to the bench and started CLEANING the exterior first. When I had it crud free, I cleaned the bench. I laid down a sheet of cardboard, got my book out and started turning bolts.
Now, I was out to fix leaks. The unit worked fine otherwise. Therefore, I didn't mess with the stop positions you mention (if it ain't broke, don't fix it). When all the guts were out and identified and laid out in the order they were removed, I looked them over real close and then looked at them again. The spools go in, in reverse from one side to the other.....hmmm. Makes sense...one is for up, one is for down. I replaced all the O rings, cleaned the innards with carb cleaner...got it squeaky clean and blowed it out. I put ATF on the spools and shoved them back in place. The heads were reset and so forth and when all was back together, I shot new paint to it. Damn thing looked like it came from a first class shop when I was done. I remounted the unit, hooked everything up good and proper and filled the system with ATF. It has worked perfectly ever since. No leaks, no hums....just up and down on demand. Somewhere along the way to grandma's house, you installed something wrong or let crud plug something up. I fear the former more than the latter. Take it apart again and really pay attention to how everything comes apart....make sure the spools come out/went back in the right way.....you can put them in reversed. They are just pistons, but if they don't pass the intake or relief ports correctly, the fluid doesn't flow right. Be patient and take your time...you'll fix it, I'm sure.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
