Re: 6vs 8v batt
Posted by John T on July 07, 2007 at 06:11:07 from (66.244.83.147):
In Reply to: 6vs 8v batt posted by jimbintexas on July 06, 2007 at 20:22:06:
Jim, I will try n take your questions one at a time: I have had starter rebuilt, replaced ignition key, and now it's in the shop with generator problems. Is this because of the use of an 8-V battery, or is it just a coincidence? thanks 1) The starter dont draw very much more current at 8 versus 6 volts so I dont really see the 8 volt batetry as a "major" contributor to starter failure. Heck Ive used 12 volts on 6 volt starters n never had any problems. 2) Ditto on the ignition key, Id say its failure is normal and a coincedence. The coil will draw a lil more at 8 versus 6 volts, but the ignition switch is rated wayyyyyyyy more amps then the max coil current. COINCIDENCE IS MY ANSWER NOTE a more normal happening when using 8 volts on a 6 volt non mag ignition system is the coil will run a tad hotter and the points will burn up sooner !!!!!!!!!!!!!!!!!!!!
3) The generator is a bit more complex. In order for it to produce the higher voltage necessary to charge an 8 versus only a 6 volt battery, IT WAS DRAWING MORE FIELD CURRENT which yields more heat soooooooooooooo over the long haul that extra field current might have degraded the field windings (and their insulation integrity) a bit. BUTTTTTTTT again there wasnt all that much added field current and its NOT the case where it would have been enough extra heat to cause any quick harm. Heck again, Ive used 6 volt gennys to charge 12 volts and NEVER HAD ANY QUICK OR SUDDEN PROBLEMS (none at all for that matter) I dont see the 8 volts as any appreciable added wear on the gennys bushings or armature so much, possilby a lil more field current n heat which would NOT increase the field windings life but its still not all that bad. I guess I would guess/attrribute the gennys failure to 80% coincidence and 20% max to extra field current from charging that 8 volt battery. John T
Home
| Forums
Today's Featured Article -
A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
