Re: Engine not running properly
Posted by Janicholson on July 09, 2007 at 17:02:33 from (66.173.50.173):
In Reply to: Re: Engine not running properly posted by Thane Johnson on July 09, 2007 at 16:49:16:
Some Ms have a drain on the bottom of the bowl. If not, Shut off the tank valva, and remove the bottom of the carb (It shaould be near full of gas, and probably is due to the fact that it will run for seconds after sitting). Lift the float gently with a finger, and (with a tin can under the carb) open the valve at the tank. (((by the way this valve should be shut off every time you get off the tractor when the engine is shut off, even for 2 min))
A stream of fuel should come out of the needle and seat about the same rate as from an excited puppy. If not it is restricted. There is also a screen in the inlet fitting of the carb. JimN
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
