Re: m puffs smoke out what iis it.
Posted by Janicholson on July 10, 2007 at 15:58:51 from (66.173.50.110):
In Reply to: m puffs smoke out what iis it. posted by james in mo on July 10, 2007 at 13:58:47:
If the smoke drifts away in a cloud it could be oil from worn guides. Especially if the smoke is also present when going down a hill in high gear and idling it down (causes high vacuum and pulls oil through intake guides)
If it smells sweet it might be antifeeze. After sitting over night pull all the plugs and have someone crank it (without the ignition on) If water/antifreeze comes out a cylinder, it is a leak. Head gasket, or cracked Head most likely.
Best of luck, JimN
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
