Re: Compression Ratio of M pistons and heads
Posted by Janicholson on July 21, 2007 at 09:43:59 from (71.87.39.51):
In Reply to: Compression Ratio of M pistons and heads posted by Tex Farmall on July 20, 2007 at 22:08:43:
Tex, Compression ratio is a math problem that for any engine has to have the measurements taken. Area of the cyl bore (Area=pi*radius of bore squared) times the stroke. This (for one cylinder) is its swept volume, or displacement. Next you need the displacement of the combustion chamber (with the piston crown sticking up from the block deck subtracted from it. Turning the head upside down and putting measured water in the combustion chamber works. Putting the piston crown into a calibrated beaker to the depth of the crown will give that difficult displacement. With the numbers, will be the compression ratio Swept volume compressed into the combustion chamber volume. The most important elememt is the compression pressure. this is a dynamic factor that on farmalls can be as high as 175 or more on some stock gas engines (or much higher on pulling engines running special fuels. Someone may respond with some numbers, but this is the best I can do. Pressure below 140 probably can use regular fuel. over 150 will need premium. JimN
Home
| Forums
Today's Featured Article -
Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
